I just wondered why the colors of a vray symbiont shd are much to dark when using the physical cam with sun/sky.
I got no idea why they are too dark but found a way to crank them up by plugin the symbiont into a blendMtl in the base mat slot and also the coat slot.
By pushing the blend amount of the coat to about 10 or 15 I get the color out of the symbiont like without the physical cam (cranking up the color values in the symbiont node doesn*t do the trick).
probably helps
rico
probably helps
rico
