ocean modifier foam
  • ocean modifier foam
    Hallo everybody,, i'm tryng to use ocean modifier on vray bat i'm no able to assign foam material from the layer generate by the modifier, i tried to save the xr file from bake ,but i have no idea.
    Maybe a layered material could work?
    I guess this will work only with node materials, working hard to release then as soon as possible.
    Currently you could try to blend the texture over some diffuse tex.
    andrei.izrantcev@chaos.com
    Support Request
      I tought about the render of the old industy of bbb3 how he have done the grafit in the lower part of the wall?
