Viewing textures in viewport
  • Viewing textures in viewport
    Hello friends, I just move to blender.
    I have a doubt on how to previews your textures in teh viewport.
    I have UVS and in mapping I select the UV and enter the layer where are my UVS, but i can't see come of the textures on my viewport.
    Any solution?
    Thanks and greetings
    Are u sure the scene is iluminated?
      no, could that be?
      I mean when you switch from solid to texture in the viewport, it's all white.
      Could it be something with lights?
      Thanks
        yes you have to put a lamp directed to the object to visualize the textured obj.
          I recommend this addon: http://blenderartists.org/forum/show...W-Map-Modifier
          Ease to select what texture shoud be displayed in viewport, and basic box mapping with real world units.
          architect at oona
            Thanks Leandro! just what i was looking for days ago :P
              So, any solution on this? The addon doesn't work as of nightly 20141219.
              Logan
              Omnia Mutantur
              logan683@gmail.com
              Origin Genesis Pro
              -i7 4790K @ 4.5GHz
              -GeForce GTX Titan X @ +200 GPU, +300 Memory x2 non-SLI
              -32GB RAM
              -Windows 10 Professional 64-bit
                I've added a double click event on "Image File" node: it will load texture into the "Image Editor" and also apply texture to the currently active UV map so it will be visible in the viewport.
                andrei.izrantcev@chaos.com
                Support Request
                  Thanks bdancer.
                  I've tried it and it's fine. Best of nothing and I think it's good for many purposes.
                  As suggestion, please add this information in the user's manual because it's one of those things that if anyone advise you, you'll never known. Or if you find a way to add in the GUI of the node...
                    bardo, tnx, I've added a label to the node.
                    Support Request
                      Any solution?
                      In my case similar to you.
                      Asiana Travel - Du lịch Á Châu is a full service travel agency providing popular Vietnam, Laos, Cambodia & Myanmar tours, Halong bay and Mekong River cruises.
