Turning off "Trace reflections" and use reflection map instead?
  • Turning off "Trace reflections" and use reflection map instead?
    Hi guys, I'm trying to setup a cheap reflection (for objects that only need a bit of generic hightlighting).
    I want to turn off raytracing and still have the material "reflecting" a simple reflection map.
    I turned off "Trace reclections" and tried plugging textures into the Environment Overrides; both on object and material. As soon as I turn off raytracing I get absolutely no reflection at all.
    Does anyone know how to do this setup? Thanks.
    "Cheap reflections" - you mean just the hilights? Have you set "Hilight glossiness" < 1.0?
    andrei.izrantcev@chaos.com
    Support Request
