create a toolbar button to turn DR on or off
  • create a toolbar button to turn DR on or off
    can someone show me how to do this ?
    I just want to be able to toggle distributed rendering on or off without having to open up the render dialog etc.
    A "dummy's guide" would be great !
    Win10.Ryzen1950X. 80GbRam. RTX3080.RTX2070.Sketchup 22.0.354.VRaySketchUp.6001. - NvidiaStudioDriver 527.37
    start script listner and then click on off on the button it will give you a command. then just drag that on ur toolbar and that should do the trick...
      thats what ive been doing - but nothing appears in the maxscript listener window. what could i be doing wrong ?
        In listener settings make sure he is listening to everyhing. Just press random boxes one of them will do the trick :P I cant remember the name now.
          I have tried activating all the options - nothing works.
          It does record actions from the main 3dsmax menus - but it records nothing from the render dialog.
          what else could i be missing here ?
            Hello,
            Basically :
            vRayRender = renderers.current
            vRayRender.system_distributedRender = off --sets DR off
            or
            vRayRender.system_distributedRender = on --sets DR on
            I hope this will help you a bit
            Cheers.
            Nicolas Caplat
            www.intangibles.fr
              thankyou - that does help. it works to turn DR OFF, but for some reason it does not work to turn it ON. I get the error -- Unknown property: "system_distributedRender" in undefined
                  Sorry, yes, it seemed evident I was only showing how the code to enable / disable DR ... obviously, the variable VRayRender must be defined first.
                  Nicolas Caplat
                  www.intangibles.fr
                    OK - thanks. i had realised it need the first sentence adding, but when i did it, it did not work - that was the problem. When i did it again from scratch (& dragged / dropped from listener again) it worked.
                    So - thankyou both for your help
