wood reflection
  • wood reflection
    I want to make a table with a wood map and a subtle reflection. I can make avery bright full reflection which looks good but if i turn down the reflection settings it gets less reflective but also has a lot of noise especially in the shadow parts.
    Anybody any idea?
    Can you show us an image?
Name:	vloergeel persp 3.jpg
      I hope you can see an image now. It is an older image because my wood material messed up and i do not know why. I had to go back to an older saved version to get it right again. I sometimes have that. I change my settings and it starts to look really awfull and i cannot get back. Anyway i do not know the settings for this image but i hope you can see what i mean.
      Regards, René
        That looks normal. Have you tried to reduce noise using the image sampler? What are your image sampler settings?
        emil mertzel
        vray4rhinoWiki
        Lookinglass Architecture and Design
          Maybe you can see what i mean on this rendering. especially the table in the back has a lot of white dots on it. My image sampler settings are min 1 and max 4. In teh materials i added a reflection map and turned down reflect to 0.6 in the glossiness section.Click image for larger version
Name:	vloergeel persp 4.jpg
