New to Vray
  • New to Vray
    Hi forum,
    I just purchased Vray 3.0 for Maya (Mental Ray Convert) and while I wait for the dongle to arrive, I figured I would ask if there was a good tutorial to reference to get familiar with Vray's functions and tools.
    Thank you!
    Les
    There is a lot of stuff on the docs site at http://docs.chaosgroup.com/ - it might make sense to look at the tutorials sections in both the Maya and 3ds Max sections.
      Thank you vlado. I will start there.
        One last question, I have two versions of Maya. 2013 and 2014.
        Do I need to download BOTH Vray 3.0 versions from the Chaos website?
          Yes, you will need to download both of the respective installations.
            Will I need two Vray 3.0 licenses, or just one?
              You will need just one license.
                Vlado,
                I am having issues installing Vray.
                When i try to render i get the error message...
                // Error: Could not obtain an interface license (-200)!
                Also, when i try to launch the vray license server i get the error:
                One of the following licenses are required:
                WibuKey 250897:7758101
                Failure reason: A suitable WibuBox entry was not found (17).
                Can you help me?
                  Vlado - see my last reply.
                  I figured out that the usb port i was using for the dongle was not reading the dongle. I switched to another port and it read it fine.
                  What i found interesting though...
                  In the default Maya render view, I would render a scene and get this error message.
                  The screen was black but it was obviously rendering something since it displayed the time it took. 7 seconds.
                  I then launched the vray frame buffer and I could see the render.
                  I went back to the default render and tried again. Same thing. Black screen with same error message.
                  I then closed the frame buffer.
                  I went back to the default render and rendered again. No error message and it worked.
                    Please let us know what is the OS that you are using.
                    In order o verify that you have the proper licenses on you dongle, please send us context.wbc file for it.
                    You can e-mail it to support@chaosgroup.com along with some screen shots of the error and details steps to reproduce it.
                    Please also include the link to this forum thread.
                    Thank you.
                    Tanya Metodieva
