Forest with VRayInstancer
  • Forest with VRayInstancer
    Hi, everyone!
    I just recorded this tutorial on how to create a forest using the new VRayInstancer.
    Hope you guys enjoy it!
    https://www.youtube.com/watch?v=KcMgPMD3SnY
    V-Ray Evangelist, Trainer and Freelancer
    www.behance.net/rickeloy
    Thanks for this tutorial
      where is the "like" button
        Well done.
          very cool technique!
          is it possible to randomize tree colors?
          I noticed you deleted the shapemerge to modify the spline, I think you don't have to delete it, you can modify the spline shape inside existing shapemerge object.
            You can use the VRayMultiSubTex map; it has an option to produce random colors based on the instance ID. This can be used f.e. in a VRayCompTex texture in multiply mode to produce some variation for a texture map.
