Thin film OSL shader
  • #16
ID:	855241 Click image for larger version
ID:	855242 Click image for larger version
ID:	855243 Click image for larger version
ID:	855244 Click image for larger version
    for all the samples: black diffuse, map in the reflection slot, GTR BRDF, 0.55 RGlossiness.
    The dome is black and white, so all the colours are from the map.
    Map parameters (fixed across the samples):
    min thickness: 200
    max thickness: 666
    rest as default.
    Changing, by 0.05 increments is the IoR, from 1.15 to 1.65 in the last example (next post)
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
    • #17
ID:	855246 Click image for larger version
ID:	855247 Click image for larger version
ID:	855248 Click image for larger version
ID:	855249 Click image for larger version
      Lele
      Disclaimer:
      • #18
ID:	855251 Click image for larger version
        Lele
        Disclaimer:
        • #19
          I have this error in Maya : OSL shader error: Could not compile shader C:/Users/damien.SDC/Downloads/thinfilm/irridescence.osl (OSL to OSO)
          www.deex.info
          • #20
            Holy sh...everytime I think I've seen everything something new comes up. So the only way to achieve this effect is to use this OSL shader? It would be indeed a great addition to the VrayMTL, and ignore clutter, the more buttons the better .
            A.
            www.digitaltwins.be
            • #21
              nice tests lele. wonder the differents in rendertimes from start to end?
              Jonas
              www.jonas-balzer.de
              www.shack.de
              • #22
                seconds.
                The effect of the shader itself on rendertime is negligible, and so quick i'd call it invariant from test to test.
                Lele
                Disclaimer:
                • #23
                  We used this thin film map just yesterday to add extra realism to a CU of an old plaster type picture frame. The frame is the really ornate type, painted gold. Took a pretty complex shader flow graph to get it to look the way I wanted it. The thin film was used in screen mode on top of the reflection channel of the base layer (in a composite map). Then we VRayBlended some VRayFlakes on top, which turned out great. Client was blown away by the subtle color variations.
                  So, thanks, Vlado!
                  • #24
                    Nice! I'm glad this came in useful
                    • #25
                      Ah, good idea on the screen mode composite map. It's still magic to me how this works :P
                      Software:
                      Windows 7 Ultimate x64 SP1
                      3ds Max 2016 SP4
                      V-Ray Adv 3.60.04
                      Hardware:
                      Intel Core i7-4930K @ 3.40 GHz
                      NVIDIA GeForce GTX 780 (4096MB RAM)
                      64GB RAM
                      DxDiag
                      • #26
                        I dunno if that is the ideal way to use it, but it worked nicely for my purpose, and renders faster than a whole second material with a blend. My surface is already slow enough with VRayFlakes as a second material blended
                        • #27
                          I desaturated and played with the hue a bit so I'm not sure how accurate this is but it's an awesome shader.
                          • #28
                            I would like to test this OSL shader but it crashes max 2011 every time I try to load it! ...any idea? ...is it supposed to work with older releases?
                            PS the same happens with the other OSL (AFMFresnel)
                            Alessandro
                            • #29
                              Looking nice!
                              In the past we would achieve somewhat similar results with Tri planar falloff maps of different colors. More artist control, I guess, but more of a pain, and not accurate (though I don't know how accurate this is after you tweak it).
                              LightWave has had a thin film shader for twenty years, and it was fun to play with. This one is much easier to use in production.
                              • #30
                                nvm got it to work, but only as osl texture in reflection map mode.
                                Dmitry Vinnik
                                Silhouette Images Inc.
                                ShowReel:
