VRay Scatter Fog node
  • VRay Scatter Fog node
    Hello!
    I know how to use the environment fog node but am not able to figure out how to use the Scatter fog node. It seems the set up process is different.
    - Do you attach it to a volume object like environment fog node?
    - Are there any special things to activate in lights?
    - What is the primary difference? I am guessing scatter fog node does scattering and environment fog doesnt, so it's more time consuming to render, but can yield more accurate results?
    Thanks
    I think it would be better to use the environment fog; it's more accurate and more complete. The scatter fog is a simple shader that we use as part of the sub-surface scattering in the V-Ray material.
      AAhhH! Thank you Vlado! And it's late Sunday night, take a day off I know I should not talk, I'm at work on a Sunday too...
