Vray Physical Camera Export from Max to C4D possible?
  • Vray Physical Camera Export from Max to C4D possible?
    Hello,
    I was curious if there were any tricks to get a Vray Physical Camera exported out of Max for use in Cinema.
    Currently I'm using the 'create camera from view' feature in Max while looking through the vray camera > going to perspective. Then linking it and exporting a fbx from there. That method is not 100% on (ignoring any animation to the focal length, vertical shift etc).
    If there is a way to get a camera over to stock Cinema that would be awesome, if there is a way to do it with Vray for Cinema needed that might be an option as well (Cinema side might have a license, I don't work in it).
    Thanks for any help!
