What is VRAY's equivalent to Cycle's HOLD shader?
  • What is VRAY's equivalent to Cycle's HOLD shader?
    sounds like "matte" in vray. Here's the shader docs: http://docs.chaosgroup.com/display/VFBlender/Wrapper
      With the alpha value of -1, it will cut a transparent area in the render. I've used it for shadow matte, but you can toggle off the "affect alpha" to disable shadows as well.
        Thanks! It helped a lot!
