How to update Vray and Phoenix on the farm with backburner
  • How to update Vray and Phoenix on the farm with backburner
    I thought this might come handy...
    I did a bunch of batches to automate the installation of Vray and Phoenix to match the speed of updates of nighties...
    The first one send a cmdjob
    cmdjob.exe -jobName "UPDATE_VRAY" -priority 100 -manager manager -suspended -progress -leaveInQueue -dontBlockTasks -group FVVFX -numTasks 8 "c:\UpdateVray.bat"
    manager is obviously the name or IP of your manager on the intranet, FVVFX is the pool of render nodes, created with BB monitor, we update the workstation normally, the numTasks is 8 because lots of nodes are in deep space sleep right now, put your number of servers to update.
    on each render nodes there is a UpdateVray.bat at the root of c:\
    which is
    "\\yourServerAdress\Installs\3dsMax\Chaos Group\Nightly\Install_Vray.bat"
    you could put that in place of the first .bat, it should work the same way, not sure why I did that...
    now this is Install_Vray.bat
    Set "LastVray=vray_adv_33004_max2016_x64.exe"
    Set "LastPhnx=phoenixFD_adv_22501_max2016_vray_30_x64.exe"
    Set "VrayPath=\\yourServerAdress\Installs\3dsMax\Chaos Group\Nightly\vray\"
    Set "PhnxPath=\\yourServerAdress\Installs\3dsMax\Chaos Group\Nightly\phoenixFD\"
    Set InstallVray=%VrayPath%%LastVray%
    Set InstallPhnx=%PhnxPath%%LastPhnx%
    Set "Vconfig=\\yourServerAdress\Installs\3dsMax\Chaos Group\Nightly\Vray_Silent_Config.xml"
    Set "Pconfig=\\yourServerAdress\Installs\3dsMax\Chaos Group\Nightly\Phnx_Silent_config.xml"
    Set "VrayDR=vrayspawner2016.exe"
    TASKKILL /f /im %VrayDR%
    TASKKILL /f /im 3dsmax.exe
    "%InstallVray%" -gui=0 -configFile="%Vconfig%" -quiet=1
    "%InstallPhnx%" -configFile="%Pconfig%"
    RMDIR /S /Q C:\Users\samples
    RMDIR /S /Q C:\PhoenixFD
    "C:\Program Files\Chaos Group\V-Ray\3dsmax 2016 for x64\setvrlservice.exe" -server=VrayDongleIP
    "C:\Program Files\Chaos Group\Phoenix FD\3ds Max 2016 for x64\setvrlservice.exe" -server=VrayDongleIP
    SHUTDOWN /r /t 0 /f
    I manually change only the first two variables with updated file names in notepad, save and restart the job in backburner...
    for the silent installs, read chaos group online help...
    I hope it helps!
    I also did a SHUTDOWN job to switch off the farm on week ends.
    cmdjob.exe -jobName "SHUTDOWN" -priority 100 -manager manager -suspended -progress -leaveInQueue -dontBlockTasks -numTasks 27 "shutdown" /s /t 0 /f
    the priority is placing it after any other job, so when everything is done, the job shutdown the server.
    It leaves a lot of errors on the manager log but it's ok...
      This might help out as well. Instead of -numTasks using -perserver can ensure that every machine is going to run the update. On a network that has computers with different speeds I've had machines complete a task faster than another and it'll pick up the job a second time and the slow machine will miss out on the update.
