VrayBlender Material Creation Setup Collection
    thanks for the link Inwermitodion. and there is also some post from member leandro_cs, which is show some node setup to create awesome materials, like fabric, wood etc. here is the link http://forums.chaosgroup.com/showthr...8-AUS-Interior
    and i am sorry for not updating it for some time. i have some work to do. i will update the mat hopefully this friday or saturday.
      That would be great gimu. I'm actually messing with some wood and metal material. That way i have hope for some metal material. Thanks for the link from leandro cs. If i find or figure some materials, i will post it here.
        One question about curves used to control fallof map (Grant workflow), do you use it only in top right quadrant, positive values? Is that correct workflow?
        - H -
          yes, that's how curves for falloff works in vrayblender. You could check this post, SreckoM.
          http://forums.chaosgroup.com/showthr...823#post684823
            Thanks! That is what I figured out.
            - H -
            • #21
              Material #005 - Various Metal (Basic)
              okay guys, here is our next material. i think it would be better if we could check the material directly in blend file. so i upload them all here.
              some of them are basic metal material that i created recently. but there are also some dirty or old ones. just put in the nice dirt map texture on texture slot.
              hope you like it.
              • #22
                here is some render of material #006 - various metal (basic)
Name:	006 - Brass_New.jpg
                Brass New
Name:	006 - Brass_Old.jpg
                Brass Old
Name:	006 - Copper_New.jpg
                Copper New
Name:	006 - Copper_Old.jpg
                Copper Old
Name:	006 - Stainless.jpg
                Stainless
                • #23
                  oh, and by the way, the object and hdri, all of them are from Bertrand Benoit. you should check this out. simple and awesome.
                  http://www.turbosquid.com/FullPrevie....cfm/ID/672841
                  • #24
                    Hey gimu Thanks very much for the new metal materials, ... but i don't know why
                    when i put texture and render, nothing happens. I only have black render and in preview material it is nothing. When i render gold budda from link http://forums.chaosgroup.com/showthr...resnell-Curves
                    i have only duffuse without metal efect. I'm wonder what version vray standallone are you using? I'm curently using vray standallone 2.25, mayby that is the reason ?
                    • #25
                      That as i was thinking i only change in standard material from GGX to any other like Ward, Blinn, Phong and everything is ok. Because GGX must be in vs V - Ray Standalone 3, and i have 2.25 for now. Thank you once more
                      gimu for that great metal materials
                      • #26
                        Material #006 - How To Make Dirt Stronger
                        it's been a while, i will try continue this thread. some minute ago, i tried to follow viscorbel tutorial about using vray dirt and how to make it get stronger effect. he uses multiple dirt on dirt. but, here i use gradient ramp to make it stronger. here is the setup
Name:	007 - Dirt Stronger.jpg
