I am not sure how to get dirt or scratches to mix with the reflection color. I tried using a Blend node without success, but maybe there is a way to use it and I am not managing the settings correctly. Anyway, I was curious about what methods artists here are using to achieve that effect.
What is the workflow to mix a dirtmap with the Reflect color?
Thank you Gimu! That is exactly what I needed to know and I really appreciate you showing all three methods. I was curious about one thing however. I was wondering what the differences are between Output and Color on output sockets. Does it matter which one is used and why? I assume they are not completely redundant, but they both seem to work exactly the same.
All plugin nodes are generated automatically, "Output" is the default socket that is added to almost all textures; some textures has additional outputs, like "Out Color", "Out Intensity", etc. "Output" is the same as "Color"/"Out Color".
Basically, I could add checks if "Out Color" presents and add only "Output" in this case.
I've added some code (https://github.com/bdancer/vb30/comm...94a6d7fb8911f9), now "Output" will be added only if "Color" doesn't present.
Just wondering out loud: do you have any sort of cleanup tool to either flag or convert old nodes into the current formats? The other day I found some bitmaps weren't loading. When I added new image texture nodes and re-linked my materials, everything was fine. I'd like to have a quick way to check if some older created nodes aren't working like their up-to-date counterparts. Then if there was a way to convert them, that would be even better.
Originally posted by bdancer View PostI've added some code (https://github.com/bdancer/vb30/comm...94a6d7fb8911f9), now "Output" will be added only if "Color" doesn't present.
It used to have an "Output" socked like described in the manual:
http://docs.chaosgroup.com/display/VFBlender/Colorarchitect at oona
Originally posted by andybot_cg View PostJust wondering out loud: do you have any sort of cleanup tool to either flag or convert old nodes into the current formats? The other day I found some bitmaps weren't loading. When I added new image texture nodes and re-linked my materials, everything was fine. I'd like to have a quick way to check if some older created nodes aren't working like their up-to-date counterparts. Then if there was a way to convert them, that would be even better.
