V-Ray animation flashing?
  • #16
    I imagine if he were to fully uninstall the cracked version and re install the free or demo versions that it would render correctly. :P
    -dave
    Cheers,
    -dave
    ■ ASUS ROG STRIX X399-E - 1950X ■ ASUS ROG STRIX X399-E - 2990WX ■ ASUS PRIME X399 - 2990WX ■ GIGABYTE AORUS X399 - 2990WX ■ ASUS Maximus Extreme XI with i9-9900k ■
    • #17
      I assure you, I was not using the "cracked" version, I was using the downloaded free/demo versions from the vrayrender.com website. In any case, I'm glad to find out that the purchased versions shouldn't have any flickering, but I found out a bit to late. my investment is elsewhere now.
      • #18
        one of the other renderers probably had an easier cracked version that didnt flicker.
        • #19
          wow... I'm not quite sure what to say, people around here sure are rude and jump to conclusions! For your information, I purchased Brazil, and I'm very happy with the results, as well as Splutterfish's one-on-one chat support. The people on their support and forums sure are a whole lot more enjoyable to be around than people around here. I made the right decision.
          • #20
            believe me, if you went into the splutterfish forum and showed you were using a cracked version, youd get about the same reception.
            • #21
              ive been using vray since the beginning and ive only seen strobing like that in one particular instance. ive seen GI strobing from low gi settings. but the luminance flicher like that is very tell-tale about something.
              • #22
                I did a test with a plane like in that avi of his and even with fairly low settings it didn't flicker even close to that.
                • #23
                  I´m having the same problem with an authorized VRay, so let´s stay focus and problem and leave the discussion away, the people that works with computer graphics don´t have time to this.
                  I make an animation using V-Ray besides the defaut scanline render and I want to present the VRay solution, but it´s variates like the example above. I try diferents settings like single frame, multiframe incremental, incremental add to current map and none works.
                  • #24
                    Show us an example ezioweb..
                    or email me
                    Natty
                    http://www.rendertime.co.uk
