How Do I render up Motion Blur
  • How Do I render up Motion Blur
    I can’t get Blender to render Motion Blur.
    What am I doing wrong?
    Setup (Website doesn’t allow me to upload the blend file to show you the file I created):
    Cube on frame 1 on left side of the camer, on frame 3 on the right side, I am rendering frame 2.
    Camera moves from bottom to top.
    So both Blurs are used - Motion and Camera.
    Tried both normal and physical Camera. Played around with various settings. I alwyas get sharp renders as if the setting was not applied at all. DoF is working, motion blur is not working.
    Could you use some file-sharing service like https://www.wetransfer.com/ or http://www.pasteall.org/?
    andrei.izrantcev@chaos.com
    Support Request
      https://we.tl/WbwHTB5Zk5
      Here is the *.blend file
        I use Physical camera, camera type Cinematic (not Still) and Shutter Angle determines blur of motion.
        Win11 Pro 64bit, GTX 970, Standalone version: V-Ray Next 4.30.03,
          Do you mean this?
          Doesn’t make a difference
            You have Blender version 2.73+ and current is 2.77+ and your exporter is propably also very old and does not support all settings.
              Edward_007, download some recent build from https://nightlies.chaosgroup.com/#/blender and it'll work.
              Support Request
                [ATTACH=CONFIG]30632[/ATTACH]
                I am using the latest official builds.
                http://www.chaosgroup.com/en/2/downl...=v-ray-blender
                http://www.chaosgroup.com/en/2/downl...ray-standalone
                Thank you, the link you have provided contained a version where the motion blur worked. Is that the place where I need to go for latest versions? It seems the official page is not updated.
                Is there a similar place for V-Ray standalone? JuhaW tells me I am using outdated version, yet it’s the lastest I have access to.
                  If you cant see Vray Standalone folder there, you can ask permission from support@chaosgroup.com, they will ask your dongle number and then you are allowed also to download daily builds of Vray Standalone.
                    Thank you.
