Hey folks. I originally posted this on e-on's forum and over at CG Architect back in August. I figured users here might find them useful too. Here’s how I got the plugins to eventually play nice. If you aren’t interested in the preface and supplementary notes please skip down to the first numbered header in bold.
Preface
I bought Ozone awhile ago and finally got around to trying to make it work with the rest of my workflow. To be sure there are a lot of quirks in getting it to get predictable results in VRay. I finally got around to figuring this out. It has been a bit of a journey and I started making notes for myself on best practices and cautions to be aware of when working with them. Given the lack of conversation out there supporting users exploring this workflow, I want to share it with the community as I don’t feel everyone should slog through the same process just to get a sweet sky.
Extra notes and disclaimers
• For those interested, ForestPack Pro appears, so far, to get along well enough with the rest of this group. Can’t see why they wouldn’t but software developed by different people has all sorts of ways of getting tangled under the hood.
• “Best Practices” is a term I’m applying lightly here. I haven’t trialed all settings and a lot more testing needs to be done to call any of these recommendations “best” by any measure. They should be a good start though. Please share your own experiences, corrections, or expansions; they are most welcome.
• Sorry but I haven’t produced any visual aides or examples yet and may not get around to it. Hopefully I’ve worded things clearly enough for the text to suffice on its own.
• Versions: I’ve been using Max Design 2013, VRay 3.4, Ozone 2015, and Forest Pack Pro 5
1) Global Ambience lighting model does not appear to shadow properly. Use the standard model:
The Ozone documentation claims it is more sophisticated than standard and will render only slightly slower. In my tests with VRay, however, GA renders noticeably faster than Standard. However, it creates unrealistic “anti-shadows”. Where you would expect to see shadows - like where objects rest on or just above the groundplane - it actually gets brighter. This is more pronounced on VRayMtls than Standard materials. This occurs on every atmosphere model.
I’m not sure what is causing this. Looking at the behavior and colour, my best guess is that light from the sky is illuminating geometry and generating GI bounces as it should but is also passing right through opaque materials and illuminating areas that should be shaded. If these areas, like the underbelly of a teapot object over a groundplane, are generating GI bounces back and forth from light they shouldn’t be receiving in the first place, they become hot anti-AO lights. I tried moving the ambient light slider all the way to “from sky” to no resolution. Moving the light balance slider all the way to “from sunlight” eliminated these anti-shadows but also any wanted contribution from the sky.
Testing with different ground geometries suggests it is not due to the VRay Plane issue (#9) below.
2) VRay Sun + Ozone for Hybrid Daylight systems
Early tests got me some good looking skies but the lighting in the scene had anomalies. Washed out light and AO, and a difficulty getting strong cast shadows are among some of the more common ones. I understand this can be an issue when lighting with HDRI’s on dome light too and a VRay Sun is often helpful in getting your direct light and cast shadows back.
The sun created by Ozone is a standard directional light, even with a photometric spectral model, is very weak with a low multiplier. This multiplier can be turned up but in many of my tests, ozone resets it to a low value when you hit the render button. I have otherwise had little luck with Ozone’s internal settings getting the relative intensity to my liking. The result is an absence or weakness in direct illumination and shadows from the apparently bright environmentally mapped sun. I initially found it lighting my scene adequately but with no palpable direct lighting or cast shadows, even with a dramatically low sun and no atmosphere/fog/clouds in front of the corona. I found that using a VRay Sun in conjunction with Ozone’s atmosphere to be a good solution but it took some duct tape and workarounds to make it functional.
The short of it is that the best results I have found is to use the VRay sun as your sun object and Ozone as your environment + sky model, matching their positions, colours and intensities in a semi-manual way, detailed below in points 6&7.
3) You might have to adjust sun brightness or physical scale to get decent photometric spectral results on reasonable physical camera settings.
Photometric spectral is much brighter than standard spectral. When using VRay exposure controls and cameras, your exposures will have to admit less light than with standard spectral atmospheres. Relative to the Ozone sky, your VRay Sun will be brighter in standard than in photometric, affecting the relative intensity of your direct-light and shadows vs. ambient. Adjusting multipliers or physical scale can rebalance this. I shoot for 0.25-0.5 on the sun lets me keep using realistic physical camera exposure settings.
4) VRAySky Environment Map + Ozone work additively.
The VRaySky environment map will work beside Ozone but will not respond to Ozone, which can be expected. While they don’t create errors or crashes, they both act as if they are the sole atmosphere/sky system and will stack light contributions. VRay will want to create a Sky Environment Map whenever you make a VRay Sun (which you will still want to). If you know you want both environment/atmospheres adding light that way, gopher it. Otherwise, I tend to deactivate the environment map so I’m only worrying about one environmental contribution to the scene.
5) Make the VRay Sun invisible:
This keeps its direct light contribution to the scene but it seems that even a time/location match produces slight differences in the position of each system’s sun. This can produce two coronas in the background and/or reflection. Even if matched positionally on a clear sky then things should be fine but this might be tricky to do. Moreover, if the Ozone sun is behind atmospheric effects like clouds or fog, your VRay corona will present an unscreened corona and compromise the aesthetic. In said cases, the VRay Sun’s corona may look unrealistically bright. You may also want to dull its brightness as it is not apparently sensitive to these atmospheric obstructions.
6) Ozone will (sort-of) track your VRay Sun and match its sun position, but not when used in a 3ds Max daylight system assembly:
I believe this is in the e-on documentation but it is worth bearing mention here. If you create a daylight system and set the sun to VRay type, Ozone will not see it. You have to deactivate it (unless you want two sun objects) and create an independent VRay Sun. If you want to govern the position of it using the daylight system rig, you’ll simply have to align and link it to the deactivated system’s sun head. This would be a nice change in future Ozone versions as it is redundant. Even then, your sun seems only ‘sort-of’ tracked, this condition is elucidated in the next point.
7) Manually set/animate Ozone’s internal sun to match VRay Sun’s.
VRay users will probably already know how the VRay Sun object and Sky map adjust their colour/intensity and the effects of atmospheric scattering according to the sun object’s position in the sky. Also, recall how Ozone’s options have a setting to match its sun’s position with the VRAy sun at render time? Apparently, it’s just the Ozone sun component that does this; the atmosphere does not.
Instead, the atmosphere’s contribution appears to refer to the position of the Ozone sun settings in the atmosphere editor even when the Ozone sun is being automatically moved to the VRay sun’s position in the sky at render time. The workaround is pretty simple: set the position of the sun in the atmosphere editor to the same position as the VRay sun so that the Ozone atmosphere is more closely reproducing light at a comparable time of day.
If doing a timelapse, your scene will still get brighter and darker throughout due to the VRay Sun’s self-attenuation but the sky’s contribution will refer to a static time of day. If your VRay sun is animated via a linked daylight system as detailed above, you will need to keyframe the timelapse again in the Ozone dialog. Make sure you set the same global location (lat/long) too. At this point, the feature where Ozone performs sun-to-sun tracking is made moot; I reckon you could disable it if you wanted.
In my first attempt at matching these timelapse animations, for a reason I haven’t been able to figure out yet, Ozone stopped following the set animation even though the preview inside the dialog showed it going through the whole animation properly.
Preface
