Color correction tools
  • Color correction tools
    Is there any workflow tutorial about matching VRay VFB color correction tools inside Fusion...
    especially the Highlight Burn!
    Since the color correction tools in fusion seems to be working between 0 and 1, it is very hard (impossible?) to match what I have in the VFB.
    Colour get desaturated, the gamma seems impossible to get back, the rgb curves don't seem to remap the same way.
    If I export a LUT, .cube, the result in Fusion is still different from the VFB...
    Needless to say, VRay VFB is a lot easier to use...
    There was a thread about using the VFB LUT files in Fusion recently, you should be able to find it if you do a search. I think the trick was adding a gamma/sRGB node either before or after the LUT correction, but I can't remember which exactly.
      Thanks!
      I will search for it...
        there is a reinhard node for fusion but 'as is' its a bit fiddly
        ill see if i can share our version
