Hi, just evaluating Vray for Blender for the moment, I wanted to ask 2 questions:
1. When watching tutorials for Vray for Max, for example, there's not just the Frame Buffer during rendering, but another window as well, that shows a progress bar, estimation of remaining time, but also allows you to recompute just the denoiser pass with new settings. Is there a way to get this in Blender as well?
2. I've seen, that it's possible to get object and Material ID as color passes, also to randomize the colors, but unless I get the ID output as a B&W pass for a single ID, or at the most as a color pass, that contains at most 3 different IDs in the R, G and B channels respectively, the borders of the masks stop working and I get fringes around objects, when I try to mask them by extracting the mask from a colored ID pass. So is there a way to output a B&W pass for every single object and material ID?
Thanks in advance
Thanks in advance
