rendering took too long
  • rendering took too long
    I am a newbie in using vray. I set up an office interior scene with 20 vray lights placed where the diffused light fittings are and placed some office furniture. I used the renderer setting shown in the url below.
    http://www.evermotion.org/tutorials/...interior05.htm
    The rendering took more than 2 hours to complete for a 800x600 size image. Is there any way to shorten it? People in the forum were talking about several minutes in rendering.
    Did I do anything wrong in any settings in the renderer?
    Thanks for your help.
    [/img]
    can we take a look at the output image ???
    settings are very scene specific ... what works in one scene may not work for another ...it should be used as a thumbrule . but using 20 vray lights without photons then i am sure it will take 2 hours . Also you have not stated what system you have.hope this helps
      20 vray light ... ..... look at the qmc and turn everything to 1 ... and see what happens ... then slowly go back on the figures until you get a descent looking render with quick times ... but you need to tell us about you scene settings.
      Natty
      http://www.rendertime.co.uk
        Activate the "store with irradiance map" option in the light rollout !!
          how do you know he has'nt !
          Natty
            Because the tutorial he is refering to does not say to do that !
              yep well spotted ... missed that one !!..
              Natty
                Here are the final images. I first use photon map to preview the result. It took around 15 minutes for each image.
                Thanks
                  forgot to say my system is P4 1.6GHz Win XP
                  amk
