how to achieve a soft lighting effect in a scene?
  • how to achieve a soft lighting effect in a scene?
    I'm doing an interior scene with soft lighting and i manage to get the lighting setup as what i want, but i'm trying to get a soft glow around the area where the lights are ie, the ceiling around the down lights to have a soften glow such as those seen in Natty's work..the overall looks become very warm, soft but the objects within stillm remains sharp looking and not blurred off (if i do try to achieve the effect using a blur filter in PS)..
    any settings or advice from you guys the expert?? natty??
    Thank you very much!!
    Hi alvin76
    yeah it's photoshop ..
    ok well basically select the area you want to glow ... copy it and paste it back in ... then apply this action to it that ive done ... it's very simple.
    http://render-time.com/vray/GLOW.atn
    RIGHT CLICK and save it in your actions in photoshop ....
    Natty
    http://www.rendertime.co.uk
      i always doing that by hand...
      thnx alot for your photohop action, that will reduce our production time
      i love vray and the shared knowledge
        thanx a million Natty! this will be very useful!
          there is also a specualr Bloom script that comes w/ max in the scripts folder, that does that straight out fo max......just run the script.....
          haven't used it in a while...
          paul.
            hows does it work ... i ran the script and nothing happend ?
            Natty
              Check your effects dialogue after running the script
              Signing out,
              Christian
                thanks for the action man.
                  you need to move the RenderEffect-SpecularBloom script into your plugins folder for it to work.
                  It will then become a Render Effect. You dont need to "run" the script
                  <EDIT>
                  or what trixian said.
                  I should read before write...hahah
                    I have made a Photoshop plugin to do this - it's called Diffuse Glow:
                    http://www.richardrosenman.com/photoshop.htm
                    -Richard
                    Richard Rosenman
                    Creative Director
                    http://www.hatchstudios.com
                      nice.....
                      thanks Richard.
                      paul.
                        great plugin richard...i'll have to play around with it
                          When I try to run Natty's Glow.atn over PS.CS, a sign appears telling me:"The command set is not currently available"
                          Why?
                          Thank you
                            WHat version of Photoshop are you using?
                            Its probably just older than Nattys version
                            • #15
                              Originally posted by Harutium
                              PS.CS
