material help !!!
  • #16
    natty,
    i can't see the images you post. Maybe the link i think.
    it's download from http://render-time.com/vray/ but nothing happened.
    Regards
    • #17
      Thanks so much Natty.
      may i ask you one more question: i indicate on the word "L" beside Fresnel refection and Glossiness, maybe you're adding some materials inside. could you explain more about it !
      Regards
      • #18
        try clicking the "L" and see what happens.
        • #19
          L means Lock ... locking the highlights and frensel.
          Natty
          http://www.rendertime.co.uk
          • #20
            Hehe. Actually (for nit pickings sake) the L indicates locking the hilight glossiness to the reflection glossiness. And the other L is locking reflective and refractive IOR to the same value.
            Signing out,
            Christian
            • #21
              thanks Natty and Trixian.
              • #22
                @ natty:
                I was looking at those material settings you got above....and was wondering if you really need a "max depth" of 20 in you reflect settings.....I would imaginve it would increase render times quite a bit.....I always set myine to max 5 sometimes less......is there any particular resone to set it so high??
                thanks for the posting, btw.....
                paul.
