Realworld Terrain inside max !
  • #16
    Hello Samuel,
    some weeks ago I have downloaded the DEM date of the area where I live. But the landscape has been very round and not very detaild.
    Do you have an idea where I could find crisp, high detailed data for my area?
    I am living in the Rhine valley very close to the border of france (2 km away). Between the cities called "Freiburg" and "Karlsruhe"
    Mirko
    • #17
      Hello,
      Did you use DEM or SRTM Data ?
      The way I described above uses SRTM Data wich should be available
      in a 76m resolution for the whole world.
      If you did it that way and you import the converted SRTM -> DEM
      into max using the habware plugin, You will get resolution parameters
      for the landscape in the modifier dialog ! By default it has a step size of
      20x20 wich will not look very detailed !!
      By the way, the SRTM ressource ftp from above is no longer in service
      and the SRTM´s are now available from here
      ftp://e0dps01u.ecs.nasa.gov/srtm/
      Be patient.. this server is much slower than the previous one.
      And I had to try several times until I could get a connection
      cheers
      • #18
        Thanks for your help.
        Unfortunately the folder "SRTM" seems not to be available anymore
        It is written in italic letters and an error message apperas when I click on it.
        I tried the folder called "SRTM30" but I think that's not the right one. I could not find my region.
        I found my region (N46E00 in the "Eurasia" folder some weeks ago. But there you will find *.hgt files. When I opened such a file in den DEM Programm, the mountains have not been very "crisp". I thought there should be some more detailed stuff available, too.
        Or is "*.hgt" the file extension of SRTM?
        Gruß
        Mirko
        • #19
          Well that´s probabely the highest resolution of this region
          that´s available to the public. You can contact the DLR the have
          38m Data.. but they want 400eur for their terrain. And it only covers
          Germany partial.
          And also take a look out of the window to make shure that there at least
          some mountains to be displayed )
          Keep in mind when open such a file in max you are hundreds of miles
          above the ground. A mountain of 50 or 100m won´t be seen to spectacular !
          cheers
