Diffuse color different in scene... why?
  • Diffuse color different in scene... why?
    Hi my first post in this forum. I'm a fairly experienced Brazil user, but is a beginner in VRay. I have a 'color' problem that I hope somebody can help me with.
    I'm trying to copy a sofa. The sofa is in dark red/brown leather. I have tryed to use the leather settings posted in this forum, but the color turns out completely different in the rendered test scene than the diffuse color in MaterialSetting. There is an image of the sofa that I'm trying to copy at the bottom of the MaterialBrowser window.
    Can somebody help me guide my material in the right direction?
    Feel free to use the sofa modell if somebody can use it...
    max7 file
    Thanks from Tim
    The test scene: (sofa is not accurate modelled yet
    My leather material setting:
    judgeing from the screen shot, it isnt assigned to the model.
      DOH... it happens ...
      Natty
      http://www.rendertime.co.uk
        Found the mistake. the reflections was to high. The material setup principles is a bit different from Brazil ( which I'm used to).
        Edit: Anybody know why I get this black dots in the shadow areas? I only use VRayLight and Lights with VRayShadows and all materials is VRay. Cant find any logical explanation. I have not changed the rendersetting from the last "good" render. The only difference is that I imported more objects into the scene (all with VRay materials)
        Chris
