Frosted glass - need help
  • Frosted glass - need help
    Does enyone knows how to create frosted glass, but with the other side reflective (like glass on kitchen unit doors). Thanks!
    Does your geometry have thicknes or is it just facing in one direction?
    --Jon
      Well, it has. It's a window on kitchen unit with about 5mm thickness.
      I wll try the glossy refractions and see what's happening. I was hoping that someone could solve my lazyness
        you just need to create a sub-object material .. one mat for the front and one for the back...
        Natty
        http://www.rendertime.co.uk
          Well I guess I wasn't aware of what you were asking. Natty comes through with the save
          --Jon
            Yeah! thats what was needed. THX Natty! I owe you one!
              :: sorry but can anyone go step by step on this one? ...thanks ::
                Yeah, is it ok to make a step by step tutorial?
                Thanks in advance!
                  frosted material should also have glossy reflections.
                  cheers,
                  K.
                    not neccessarly. Take a look on some frosted glass window and you would notice that it almost have no reflections. You would just kill time with more glossy reflections that wouldn't be visible at all.
                      I know it doesn't reflect much, but reflect it does.. and them reflection's being low gloss.. It looks nicer, and turn down subdivs for less render time.
                      I guess it's also a matter of priority, if it isn't a vital part of a design or composition reflections could be turned off.
                      Ofcourse reflections being glossy or not depends on which surface you look at, the frosted or the non-frosted.
                      Nothing like silky glass though.
                      Cheers,
                      K.
                        Argee!
                          Well would you show you material settings or share the material, It would be very nice to have it.
                          Thanx in advance.
                            will do ..... baby's to worry about at the moment ..
                            Natty
