can someone please give a detailed explanation what are the pro´s and con´s of the skylight portal feature and what are the other option (store with irradiance map) are good for.
should the GI solution not work correct without the skylight portal used for windows?
is it only to bring more light into a room?
if the answer is yes then why not use a normal vray light?
i don´t get the principle yet.
thanks for your time.
