Hi everyone,
I would like to know if there is currrently a way to increase the effect of a bump map in the material controls or elsewhere. For example, I have tried increasing the Bump amount value as well as the Bump texture multiplier above 100% (to 500% or even 1000%) and the result is exactly the same as if the values are default. Is there a way to do this or is it just broken? I know in 3DsMax you can make the bump effect more intense by cranking up the multiplier next to the bump slot.
Thanks in advance!
Thanks in advance!
