Bad frame render - how to fix it ?
  • Bad frame render - how to fix it ?
    This happens almost at every animation i try to render, 1 or 2 frames are very off, like in the image bellow. I tried to made new scenes but i keep getting this error.
    I even tried to render just those 2 frames but they are exactly the same.
    Btw when i export Animation Image Set in Sketcup without rendering i dont get this issue.
    What can i do ?
    Hello,
    Does the issue occur only with this specific project and these specific frames?
    Do you use any 3rd party extensions related to the scene creation in your project?
    Could you please share this project (or any other exhibiting the same problem) by using Extensiosn > V-Ray > Export > Pack Project and then sending the archived file to support@chaosgroup.com with the rest of the requested information?
    Kind regards,
    Peter
    Peter Chaushev
    Let's keep in touch
      Yes Peter i will send those file to support@chaosgroup.com
