falloff challenge! faking stretch metal opacity
  • falloff challenge! faking stretch metal opacity
    I've got a task here that I initially thought was easy as pie. But it turns out it's not?
    I'm trying, to without building geometry or displacing, simulating the fact that a fine meshed strech metal sheet looks more or less transparent depending on the viewing angle.
    Is the following doable: have a vertically oriented surface have one value when viewed from above, and one value when view from below? I was hoping I could do it with falloff, but I can't figure it out.
    Not a v-ray specific problem. I'm just hoping someone here has an idea that could help me Cheers!
    An image of the effect you're trying to create would be helpful.
    Edit: Above/Below can be done with the falloff texture in axis mode, just like you would make a mask that way for depositing dust only on up-facing surfaces.
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
