How light size affects sharpness/softness of shadows
  • How light size affects sharpness/softness of shadows
    Hi guys,
    I made a short animation showing one of the fundamental rules of studio lighting in photography (and by extension lighting in V-Ray) that the bigger the light source is in relation to the subject, the softer the shadow. And the smaller the light source, the sharper the shadow.
    So,
    big light = soft shadow,
    small light = sharp shadow
    I had to animate the camera's exposure control to compensate for the light intensity increase caused by the increase in size.
    I made this animation for educational purposes. I think this is one of the most important, albeit simple, concepts in lighting that I see many amateur photographers having a difficulty to grasp. Hope this helps someone out there!
    Thanks for sharing!
    Simply, I love to put pixels together! Sounds easy right : ))
    Sketchbook-1 /Sketchbook-2 / Behance / Facebook
      Originally posted by M.Max View Post
      Thanks for sharing!
      You're welcome, M.Max!
        You could use size-invariant units for your lights (Lm, W), and avoid the issue altogether.
        cfr. : https://docs.chaosgroup.com/display/...+%7C+VRayLight
        Lele
        emanuele.lecchi@chaos.com
        Disclaimer:
          Oh wow, of course! Saw your response just now after months. Thanks. Learned something new today.
          Turns we have even more control over light than I thought.
