I started going through the tutorial, but I've never used Gradient mapping like this before.
My problem is I cant get it to fill the shaded area cleanly.
See the attached images
When I adjust the location of the gradient it goes too far the other way
I'v tried just about everything I can think of but as you can see from the second image,when I move the slider too far, I get a strange sphere effect.It almost looks like a mapping issue, but I don't think it could be.
make sure there is a softer edge to those two inbetween points it should soften up that circle your getting, my 1st attempts were with falloff using light/shadow but it didnt give me as much control as the gradient ramp was giving me.
I turned the softness of to exagerate what I was talking about. But I think I have it pretty close.
My water material needs work though. Can you point me to the material converter. I remember seng that posted not too long ago but I cant find it now. BTW why are converting the EGZ glass material?
BBullo:
There isnt a script, you just type in the script your self into the maxscript window. Just make sure you change the number of your material if yours doesnt happen to be 3 like Da_Elf's
thanks guys. i guess it was about time i sat down and wrote that. i had mentioned i would do a tut a while back since i 1st this image http://www.elfpro3d.com/bigcnet.jpg
Really nice tutorial, but I think you have to post your light settings, because they play a big role where the caustics map will display (because of the gradient ramp map - when it is set to lighting, it is dependable on the light).
that could work too. however you wouldnt have the control to be able to stop the caustics from going above water. as a material effect you get better control. also...and i point to BBulos problem. the reason he was getting that area was because (and i had to fight with this too.) the falloff map and gradient map take the total amount of light and shadow into account. meaning that its not just from the direct light but also from skylight. which if there is a tiiiiny bit of caustics bled into the shadow area it wouldnt be so bad in my oppinion.
