How in 2022, can anybody still use values above 200 for white in diffuse? - SUV_002
  • How in 2022, can anybody still use values above 200 for white in diffuse? - SUV_002
    Particular model, but I'm sure there's others
    SUV_002
    has a white of 234,234,234
    Kind Regards,
    Morne
    Hi Morne,
    Thank you for pointing it out!
    I can see that other vehicles have the same/similar setup.
    I added a task on Jira to fix these values.
    Tsetso
    Tsvetan Milanov
    Chaos
      Thanks for the quick response
      Kind Regards,
      Morne
        Hi again Morne,
        This is just a quick update from our side - all vehicles with white color in the diffuse are now fixed (they don't exceed the value of 200).
        For the models you've downloaded already you'll see an "update" label over the preview image.
        To update the model, click on it to open the detailed view and under the "Import " button where it says "New asset version is available", just click on "Download now" - see the attached screenshot.
        Best regards
        Tsvetan Milanov
        Chaos
          When using ACES, fresh snow is around 243, white acrylic paint is 227. So values above 200 are not wrong.
          Florian von Behr
          CG Supervisor
          The Scope GmbH
          Behance
