Chaos Cosmos doesn't see config.json?
  • Chaos Cosmos doesn't see config.json?
    Even if C:\Program Files\Common Files\ChaosGroup\ChaosCosmos\config.json is set to a suitable unavailable proxy server as follows, Chaos Cosmos will access the Internet. (Of course I restarted cbservice.exe.)
    "proxy": {
    "type": "http",
    "host": "121.12.1.8",
    "port": 80,
    "user": "",
    "password": ""
    This is a connection test of Chaos Cosmos via Proxy, but I cannot determine if Chaos Cosmos is connecting via Proxy.
    tested Chaos Cosmos Build: 2023.04.26-311864
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Hey Yuji,
    Thanks for posting. If Cosmos Browser cannot connect to the configured Proxy, it falls back to "no proxy" configuration.
      Thank you for the information about falling back.
      I'll try another way to check connectivity through the proxy.
      oakcorp.net
      v-ray.jp
