I'm working in 3ds MAX and Corona and placed Cosmos assets in. Initially all at the correct scale, but now I reopen the file and all my assets have shrank. What's the deal and how do I fix this issue?
Cosmos Assets shrank
Hi, thanks for posting. What system units are you using? When you change the system units the proxy scale parameter is changed when you import from Cosmos so the object size corresponds to the scens's units. This is not the case for any other geometry in your scene.
So most probably your geometry is not in scale if you have merged it improperly or changed the system units midterm. You can adjust the proxy scale manually but this is not practical with many proxies.
