Cosmos in Maya
  • Cosmos in Maya
    Is there an option not to bring/load the textures into the Hypershade and turn into a gigantic mess, since I'm not going to tweak any settings on any shaders?
    And LODs where are they? Trees for example , do they come with LODs or this only means displaying them as bounding boxes in Geometry to load tab? Maya 2023 Vray 5 windows 11
    https://www.artstation.com/damaggio
    Hi, probably something like the idea that stezza suggested here? Are you both talking about the same thing?
    Vladimir Krastev | chaos.com
      Hi Vladimir, no the other posts are about cleaning up the nodes left behind after "Optimize scene" in Maya, I'm asking if there's a way to not upload the textures into the Hypershade when
      you import a Cosmo asset, I still want the proxy to render with the textures of course, is that possible ?
        Hi sorry but I still do not understand the issue. Here is how my Hypershade looks like after importing a Cosmos tree:
        Click image for larger version  Name:	download?id=1vj4rMGDr7aurrZyBNTr0lzqT3nYqgRxa&authuser=0.png Views:	0 Size:	314.3 KB ID:	1213985
          That's what I mean Vladimir, Hyperhade "TEXTURES" area gets populated with all the shading nodes, one single tree might have 4 shaders and about 20 textures, imagine when you are working on one environment is
          a nightmare trying to stay organized. I wish there was a way of not importing the shading network since I'm not tweaking any proxy shaders and if I need a specific one that is not working quite right I could re-import that one with the
          shaders so I could modify if I want. I think if there was a check box somewhere where you could tic > "do not import shading network" , that would be for any assets , cars, people, furniture, any Cosmos asset...that would be fantastic.
          Unless I'm not aware of a setting or option in the Cosmos browser, I look into it but did not find anything.
          And currently, if you delete a few tree proxies , these nodes stay behind after you do an "Optimize Scene Size"
          Thanks for looking into this.
          Click image for larger version  Name:	Hypershade.png Views:	0 Size:	85.4 KB ID:	1214012
            Hi, there does not seem to be a workaround to this. Please log a feature request in our ideas portal. If more users join and vote for this improvement we will consider developing it if possible (it may be a limitation on Maya's side).
              Okay Vladimir, thanks for asking around, I'll make a proper request then. Cheers.
