chaos cosmos paths
  • chaos cosmos paths
    if you have to use two different workstations not in the same LAN network, how do you set the paths of Chaos Cosmos correctly? So that you don't lose the resources and texture paths, I mean
    I created a folder on both PCs and assigned the same letter X using the Windows function "connect network drive" but the result is that it is slow when opening files.
    Hello,
    Which version of C4D are you using, and also which version of V-Ray/Corona?
      Originally posted by hristo_chakarov View Post
      Hello,
      Cinema 4d 2025.0.0 and V-Ray 6 for Cinema 4D, update 2.3 (v6.20.03 from Sep 11 2024)
      thanks
        Hey there! I've checked w/ V-Ray for C4D team. There is a "Cosmos Assets" recovery functionality. You don’t have to use the same paths on your different computers. I've just tested this with a scene created on a Mac and then recovered it on Windows. You have to go to V-Ray –> Tools –> Download Cosmos Assets:
        You have to confirm that you want to download the assets:
Name:	Screenshot 2024-09-18 at 15.35.06.jpg
        And your scene will be recovered. Note – if the asset is already downloaded, it won’t be downloaded again, only relinked.
        Hope this helps!
          thanks! i'll try
