Chaos Cosmos folder inefficiency
  • Chaos Cosmos folder inefficiency
    Viewing assets via Cosmos is not always practical, such as when internet is down. Cosmos downloads materials and 3D models to a Cosmos folder in Documents. Browsing that folder means looking at folder titles, not thumbnails. A user must open each folder and drill down for a preview. Is there a way to place a jpeg or png thumbnail alongside each folder, so I can see the content without needing to drill down through the folders? For Cosmos to function, is it necessary to retain the Cosmos subfolder configuration? For example, could I move each folder's contents to a single level so the thumbnails display with the supporting files when sorted by filename? (Assumes all subfolder files share the same name.)
    Is there a way to store materials I create with Cosmos assets so that when I do or can open Cosmos I see the materials I created among the Cosmos materials?
    Thanks, Jeff
    Hey Jeff,
    In order to browse your assets you'd better use the Cosmos Browser. It will automatically enter in "offline mode" when your internet connection is down (of course, if you're using a recent version of the software). Browsing assets on your file system, as well as modifying their files, is discouraged. Modifications will make them unavailable for imports, etc.
      Hristo,
      What about materials, such as PBR, that I create or legacy materials preceeding Cosmos? Do I move those into Cosmos? If so, how?
      Thanks,
      Jeff
      ps. The internet was not down. A Windows setting enabling a fast restart was disruptive.
        Hi Jeff,
        Currently, we don't support moving custom materials/models to Cosmos. This feature is under consideration and has been added to our Ideas Portal for further discussion. Please feel free to share your feedback as a comment or by completing the attached survey.
        As a temporary solution, you can use the V-Ray Asset Editor to store your custom materials.
        I've included an example setup below:
        Tsvetan Milanov
        Chaos
