Exposure changes when Using direct link to 3D Max
  • Exposure changes when Using direct link to 3D Max
    I am working on this scene it is being light by a dome light and one HDRI. While doing model changes, I fired up Chaos cosmos and every time I moved the object or the viewpoint the exposure reset to default, so everything is very bright.
    I am not use a camera yet just the perspective from 3D Max.
    If I adjust the exposure inside Chosmos it looks fine, but as soon as I rotate the view everything goes nuclear again.
    Why is this?
    Thank you
    Hi, thanks for posting.
    Are you using viewport IPR.
    What objects are you merging? Are they models or HDRI lights?
    Are you using exposure and how do you apply it? Are you using auto exposure?
    A recording of your screen that demonstrates the issue might help with troubleshooting.
    Vladimir Krastev | chaos.com
      Vladimir, thank you for your answer, but I just realized that I posted the question in the wrong forum. The issue I am having is with Chaos Vantage, and not with Chosmos.
      Sorry about the confusion. I will post the question in the correct section, thanks.
