Cosmos Assets in Grasshopper
  • Cosmos Assets in Grasshopper
    Is it possible to use grasshopper to distribute and render cosmos assets?
    Hi andreas_schermann
    Yes, it is possible. You can merge the desired asset so you can copy-paste the proxy file location in the V-Ray Proxy Mesh File Path slot.
    Merging the asset will also show the Proxy Mesh' materials which you can then select from the V-Ray Proxy Mesh Material slot - just make sure they are in the correct order.
    There are a few ways to distribute the proxies. You can basically achieve that with V-Ray Instancer or you can instance the Proxy Mesh itself, as demonstrated in the attached images. Hope this will be of help!
    Click image for larger version  Name:	2021-03-30_14-46-05.jpg Views:	0 Size:	309.1 KB ID:	1109225
    Click image for larger version  Name:	2021-03-30_14-49-13.jpg Views:	0 Size:	326.9 KB ID:	1109226
    Nikoleta Garkova | chaos.com
      Problem resolved. Thank you
        Hey daniel_silver,
        Glad to hear!
