Edit Chaos Cosmos Objects
  • Edit Chaos Cosmos Objects
    Hi there,
    is there a way to edit (delete part of the geometry) the Chaos Cosmos Objects?
    Kind regards,
    Pedro
    Dear pppppp_mmmmm​, hello.
    Within SketchUp Cosmos assets could be merged to edit their materials, described here.
    And no further modifications to the mesh are expected, see here.
    But please share examples - what do you want to change?
    We will appreciate to know more and what could we provide on this matter in the future.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      Hi Tsvetomira,
      Thank you for your answer.
      In this example, I wanted to remove or resize the base of the tap because it was not properly modeled and caused this odd reflection.
      After merging it, I tried to make the intended changes and the model just disappeared from the render.
      I ended up using the original model from the creator, made the necessary changes and exported the proxy for use on my model.
      Kind regards,
      Pedro
        We've updated the asset. Thanks for the feedback.
        Miroslav Ivanov
        Chaos Cosmos
