Hi there
from my very first tests on Envision, I must say that i'm really impressed with this new software... I'm a C4D+V-ray user and I use very often Vantage to render animations, but the UI of Envision is super cool and very intuitive (some of the things are not
but in general this UI should be moved to vantage or maybe unify both...
but in general, great work Chaos Envision team
some thoughts from a C4D+Vray user and exported scenes:
- all the cosmos objects that we have in c4D+vray scene, open with wrong orientation axis
- there are some v-ray shaders that won't load (example layered shader; 2side mat; UVWrandomizer; etc) It's possible to have a list of unsuported things in Envision?
- imported trees (not Cosmos trees) won't assume the two side materials or even refraction SSS... It's possible to have a list of unsuported things in Envision?
- Decals not imported in vrscene... It's possible to have a list of unsuported things in Envision?
- normal map bump won't load. would be awsome to add the possibility to fine tune materials like the ones we can tune in Cosmos materials...
- bump slot does not work at all (bump or normal bump)
- displacement won't assumed in imported vrscene... It's possible to have a list of unsuported things in Envision?
- seams that randomization is not working on materials (at least i've tried in some cosmos materials and is not working as expected) can you confirm?
- I think that should be added a set of water presets (something like vantage, but better integrated, like animated trees and so on)
- would be possible to add animated textures to a slot? for example to displacement (animated water)?
i'll keep making some more tests to give you more feedback
thanks
best regards
nuno
ps i've attached a list of warnings when imported the vrscene in envision.
thanks
best regards
nuno
