cant find license on startup
  • cant find license on startup
    Do you need to have a license of vantage to run Envsion?
    Its shows "initializing choas vantage" in the corner of the startup window and then says it cant find license. I have followed the instructions from the troubleshooting guide on what to do if it cant find the license - ie terminated and restarted the programs listed in the task manager. However it still doesn't work
    Please advise
    Cheers
    Hello, this is likely due to a bug or some issue with the unified login, there is no vantage license dependency anywhere. Are you using a remote server or local to authenticate?
    George Karampelas
    QA Specialist
    www.chaos.com
      Hi George,
      No, normal login. I can use Vantage, and Vray for rhino without issue
        Originally posted by blueskydesigngroup View Post
        Hi George,
        In that case it is possible there is an issue with the account licensing, can you please contact our customer support and ask them to verify if everything is fine with the beta access and your account? If the issue persists please report back here, so we can consider alternatives.
        Best,
        George
        George Karampelas
        QA Specialist
        www.chaos.com
          I have an Enscape fixed license and am getting the same "can't find license" issue. Also within Enscape there isn't an option to export a file type suitable for Envision. I would like to test Archicad/Enscape/Envision workflows, but I have hit this licensing roadblock.
          Regards Nathan
          Regards Nathan
          Nathan Hildebrandt FRAIA
          Director | Skewed Architecture
            Regards Nathan
            Hi Nathan sorry to hear you are experiencing issues with licensing, have you tried the solutions over at our troubleshooting page? https://docs.chaos.com/display/ENVISION/Troubleshooting
            If the issue persists please let us know so we can consider alternatives.
            Best,
            George
            George Karampelas
            QA Specialist
            www.chaos.com
              Regards Nathan
              Which version of Enscape are you currently using?
              Ana Lyubenova
              Product Manager
              www.chaos.com
