importing a second project giving strange artifacts
  • importing a second project giving strange artifacts
    i have a base scene,.., and i am trying to load in a project.. some how the newly loaded model is taking elements from the base scene,
    in enscape it is only the structure but when i load it into my envision project i also get these strange lines
    Hi arno, note that this issue has been logged internally [EC-1487], and our development team is actively working on a solution. A temporary workaround is to export both scenes in the same .vrscene, or ideally match the unit-scaling of both separate scenes to be the same.
    We appreciate your patience and understanding as we work to address the matter.
    George Karampelas
    QA Specialist
    www.chaos.com
      Hi George, Understand the work around,., i am just looking into a workflow for our company.. we will use a basic scene and load our structures into that... if we can have that we will use envision for almost all our projects
      Click image for larger version  Name:	image.png Views:	0 Size:	836.1 KB ID:	1225095
      opened the project again and the stange lines are gone.
      you can also see that most of the strange artifacs like elements from the scene in the structure are gone.. only have some strange bushes that should be some other objects
