can't swap all element materials at once
  • can't swap all element materials at once
    trying to swap a material..
    selected an object, grabbed the material.. did select all..
    then drag and drop an cosmos material on the elements... but only the element i drop it on is changing material.. not all selected
    Hi arno, the current functionality requires a material to be applied > then applied to selection through its details panel, we are aware of the limitation this might pose and considering improvements along the line.
    Best,
    George Karampelas
    QA Specialist
    www.chaos.com
      george_karampelas i am not fully understanding... is or isn;t it possible could you clarify with some images
        For the moment it's only possible through the materials tab, i.e. you have a number of nodes or objects selected navigate to the materials bottom panel - select its details - apply to selection. From the materials tab you can also do ctrl + drag and drop over to a selection.
        Sadly it doesn't work through cosmos panel for the time being, this can possibly be improved in the future. Please let me know if you have any further questions.
        George Karampelas
        QA Specialist
        www.chaos.com
