Hi, RoomBox interiors works nice in Vray renders, but since lights are on only at nights in Envision, i can't achive the expected resaults, my interiors are dark in daytime renders. Secondly, we can't adjust intensity of them and it is a huge problem. Vray lights are having problems while converting the values to lumen i guess, it comes overexposed to Envision.
RoomBox interiors issue
Hi, I'm not sure if I understand your post correctly. Could you please clarify:
Thanks in advance!
- Likes 1
Originally posted by marcin-corona View PostHi, I'm not sure if I understand your post correctly. Could you please clarify:
What exactly do you mean by that? You can use lights in Envision regardless of day/night time.
Do you mean the intensity of lights exported from V-Ray?
Do you mean any V-Ray light you create? Could you post some example images showing this problem?
Thanks in advance!
We can't adjust Roombox lights, i think they use emissive lights in their interiors, no problem adjusting Vray lights..
In daytime my roombox interiors were dark and in night time they are overexposed, again, auto exposure was one of the reason..
When i tried to open my original file, created and saved as "linked" imported vrscene, i got an oops message.. Here is the details. I can't resize the error window, so i took two screen captures. I will upload the report after work, because most of the web is out of reach at the office..
Hi, i tested on a newly created file, and it seems some problems are just appearing on my one particular file. For example, colorcorrection tab is unstable on that file, when i change somthing it jumps in general tab, i have to switch color correction tab after every move.. But mesh light issue is the same on new file. It looks like the attachment and no matter how high is the value, it doesn't work..
Could you please:
- try the newly released beta update 3 - https://forums.chaos.com/forum/chaos...-beta-update-3
- if the issue is still there - contact us at https://support.chaos.com/hc/en-us/requests/new
Thanks in advance!
- Likes 1
Thanks in advance!
https://www.mediafire.com/file/g1m47...ports.zip/file
Originally posted by kenancakir View PostHi, i tested on a newly created file, and it seems some problems are just appearing on my one particular file. For example, colorcorrection tab is unstable on that file, when i change somthing it jumps in general tab, i have to switch color correction tab after every move.. But mesh light issue is the same on new file. It looks like the attachment and no matter how high is the value, it doesn't work..
Hi, It seems most of my problems are my fault. The problem was auto exposure and mesh lights, when i turn auto off, overexposure problem gone. Except mesh lights, they are not working.
Regarding the error dialog please note that there is an option to export it as a .txt file, the option is inside the warning/error dialog window.
Originally posted by george_karampelas View Post
This might be related to an issue we've discovered recently since it points to the same exception, however it is still under investigation EC-1670. Can you successfully reproduce it every time you attempt to open your scene, if so yes can you share it with us?
- Likes 1
