Chaos Player, update 1 - now available
  • Chaos Player, update 1 - now available
    Hey everyone,
    We've released update 1, bringing Contact Sheets, ability to set Color Mapping defaults, and quality-of-life improvements.
    You can use Contact Sheets to visualize different versions of a shot and pick the best one, or lay out your render elements and make sure all the data is there.
    You can now save Color Mapping settings per file type, use common playback hotkeys, work with updated UI component names, and more.
    The builds are available on our website.
    Here's the full changelog:
    New Features:
    (*) Contact sheet;
    Modified features:
    (*) Added an option to choose a default color mapping table per file type;
    (*) Updated playback hotkeys with J, K, L to for play backwards, stop, play forwards;
    (*) Added additional ALT+ hotkey binding for choosing the R, G, B, A, L image channels;
    (*) Renamed some UI elements with more intuitive names;
    (*) Added flag aliases with the new more intuitive UI element names;
    (*) Added a --frame command flag that aliases the --time flag for setting the current frame;
    (*) Color sampling now shows a fixed number of digits in the information bar;
    (*) Removed the e-mailing options from the menus;
    (*) Associated .TX files with Chaos Player
    (*) Updated OpenEXR to version 2.3.0;
    Bug fixes:
    (*) Fixed command-line export not working because of wrong order of passing the flags (--save*, --export*);
    (*) Fixed halted script execution caused by some command flags triggering pop-up messages;
    (*) Fixed corrupt header error thrown by DWAA compressed EXR files in some cases;
    (*) Fixed numpad hotkey bindings for changing the FPS not working;
    (*) Fixed clamped pixel info values with .HDR files;
    (*) Fixed files with multibyte characters in the filename do not open;
    (*) Fixed a crash when deleting multiple layers in ABCD wipe mode;
    (*) Fixed missing file association for Chaos Player composition files;
    (*) Fixed segmentation fault on exit on Linux;
    (*) Fixed installation warning on Linux caused by missing check for the "chaosplayer" symlink;​
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
