Hello,
I like to render my frames in Deadline at 'Half Raster Refine', which allows me to render out frames in a sequence in a 'stagger-then-fill' way. For example, if I render out a frame range of 1-100, Half Raster Refine will render out frame (1,10, 20,30,40,50,60,70,80,90,100) then (5,15,25,35,45,55,65,75,85,95) then (3,8,13, etc. ). This allows me to get a glimpse of an entire render sequence early, without having to render the entire thing first. Good for quality control.
The problem is, when I want to check completed frames while the sequence is still rendering, I have a ton of gaps in between frames, and Chaos Player likes to smash the frames together and render them back-to-back, rather than holding on missing frames. This results in super-fast playback and is unhelpful.
Is it possible to hold on missing frames, so that I can preview an animation that has gaps in between completed frames, without having the frames all accordion together? Does that make sense? Let me know. Thank you!
Cheers,
Andy
Cheers,
Andy
