Can´t activate
  • Can´t activate
    Hello.
    I´ve downloaded Chaos Player to try out, but it doesn´t recognize my license server.
    Tried to move the license to local and the same window pops up.
    See if changing the license settings from here helps: "C:\Program Files\Chaos Group\Chaos Player\bin\setvrlservice.exe" (or look for Change Chaos Player license settings in the start menu).
    Doesn't it help if you enter a valid IPort on the window in your screenshot?
    Do the rest of your Chaos products keep working (i.e. they find the correct license settings)?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      Yes, everything is working with other products. IP addresses are correct.
        Can you make sure that your licensing account has a Chaos Player license?
        The easiest way to do it is from the license server's interface (locahost:30304)?
        Alex Yolov
        Product Manager
        www.chaos.com
          I don´t because i´ve download as a tryout, and not a full license.
            It seems you don't have a license on your account. Even trials add a temporary license to your account, so some step definitely didn't go right.
            It would be best to contact our support team following this link: https://support.chaos.com/hc/en-us/requests/new and they'll help you sort this out.
            Alex Yolov
            Product Manager
            www.chaos.com
              Tks, but not worth it right now
