Chaos Vantage v1.5.2 released
This is a sticky topic.
  • Chaos Vantage v1.5.2 released
    Hello everyone!
    We are back with a new update - v1.5.2. Here are the highlights:
    • Added configurable material preview swatches, and an updated Materials UI tab
    • Added new Live Link animation render button in 3ds Max
    • Changes made to lights are now saved to .vantage files
    • Added top/bottom option for stereo output
    • Added command line wrapper vantage_console.exe (see vantage_console.exe --help)
    • Added .vantage file association in Windows Explorer
    • Improved translation tool: now does surface placement with the center cube
    • Improved animation editor: multiple UI tweaks, new "Shot" mode
    • Improved UI: added more tooltips
    • Improved performance when loading a .vantage file that imports Cosmos assets
    You can find the full change log here:
    https://docs.chaosgroup.com/x/DgihAw
    You can download the update from here:
    https://download.chaosgroup.com/?platform=47&product=63
    Edit: We released a quick hotfix that can be downloaded from the same link above.
    You can see some of the new features in use here:
    Best regards.
    The Chaos Vantage team
    Hello everyone!
    We released a new version 1.5.3 and it has the following improvements:
    • Implemented HDRI environment and dome light creation and updating
    • Material name searching, type filtering and sorting(name and creation)
    • Select the material of the selected object button
    • Drag-and-drop material assignment with preview
    • Alt+drag-and-drop replaces material on all object with same material
    • Ctrl+drag-and-drop assigns material to objects and its children
    • Initial support for ply, obj, bin, geo, hclassic, bgeo, bhclassic, prt, alembic (static) files
    • Optimized memory usage of texture files with a single color
    • Optimized memory usage for material previews
    • Cosmos browser doesn't show importer choice inside Chaos Vantage when multiple importers are running
    • Motion blur is not allowed for non-perspective (Cube 6x1, Spherical and stereo) cameras.
    For the full change log click here:
    Best regards.
